6/19/2014 9:16 AM | |
Joined: 11/21/2007 Last visit: 6/24/2024 Posts: 2324 Rating:
Hello Pl check out this Update : http://support.automation.siemens.com/WW/view/en/59903098 It is clearly mentioned that : The sync modules have also been newly designed and are not compatible with the old modules.The FOC sync cables have not changed. You need the old version Sync modules for your V4 CPUs ONLY Cheers Navnag |
There is no such thing as the last bug in a program |
9/11/2017 8:43 AM | |
Joined: 8/21/2014 Last visit: 6/26/2024 Posts: 972 Rating:
New question published by shahyamin is split to a separate thread with the subject One of my sync module (6es7-960-1aa00-oxao) is damaged. I need any replacement for it. . Best regards |
