3/3/2011 6:44 PM | |
Posts: 27 Rating:
Hi, Thanks for your reply, i know that only one CP1613 is enough, but the client wants two!! Thanks. |
3/3/2011 8:26 PM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating:
Hello medaadi,
The CP1613 A2 will work if you have PCI slots in your PC If you have only PCI express slots in your PC then you should use CP1623.
It's the first time to know about the 6GK5307-2FD00-3EA3. Itshould workbut I'm afraid it might be expensive. Try to compare its price against 6GK5308-2FL00-2AA3. Try to go through the IKPI catalog to get more info about the subject I have a small comment. In your configuration, each CP1613 talks to a single CPU and in this case you will lose a major feature of your CP1613 that it can talk to both CPUs (CPs) with the aid of RED. CONNECT. It will bebetter if you link both switches together. Don't forget network printers if you have them. Add necessary ports to your calculations.
Check RED. CONNECT. For WinCC, you can buy a 128 RC license (6AV6381-2BM07-0AX0) that will let you design your WinCC screens and use 2048 RT license (6AV6381-2BE07-0AX0)for each PC station.
It's a software that you will not need when you buy the CP1613 and RED. CONNECT I we both didn't Best regards. H-H |
