8/7/2013 3:04 PM | |
Posts: 557 Rating: (64) |
Hello, |
8/7/2013 3:12 PM | |
Joined: 9/27/2006 Last visit: 8/6/2024 Posts: 12273 Rating: (2680) |
Hello Eastern; The part number you have shown is for a redundancybundle package, which includes 2 of the mentionned AS. If you look up the exact part number of your CPUs in the Product Support pages, you will find this update information: Hardware Upgrade Package "HUP CPU410-5H" Available for Download The Hardware Upgrade Package "HUP CPU410-5H" is required for the configuration of the CPU 410-5H Process Automation with the engineering software SIMATIC PCS 7 V8.0+SP1. It integrates the CPU 410-5H Process Automation into the hardware configuration with HW Config. |
8/7/2013 4:36 PM | |
Hello Eastern; I have no answer for you. I hope you have some patience with the official process. Maybe you could issue a Support Request to ask when you registration will be processed? Regards, Daniel Chartier |
8/8/2013 2:49 PM | |
Joined: 9/1/2005 Last visit: 8/1/2024 Posts: 4104 Rating: (194) |
Follow up question published by Easternis split to a seperate Thread with the subject PCS7 V8.0 - Integration Hardware IPC 277D, 10". Best regards CS Moderator |
8/8/2013 2:56 PM | |
Hello Eastern, I can confirm, that there is a export restriction for the download you tried to make. With the assistance of a colleague we have checked the state of your registration inquiry. It is still in process. I have to say that at the moment there are a lot of inquires. So it will take some time to check all of them manually. An automatism isn't possible. Best regards CS Moderator |
9/11/2015 2:08 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4769 Rating: (123) |
New question published by nkr is split to a separate thread with the subject MLFB not in catalog. Best regards |
