10/13/2023 1:42 PM | |
Joined: 8/3/2009 Last visit: 5/17/2024 Posts: 12970 Rating: (1650) |
Hello bilal_ghouri49 I think with SIMATIC NEt OPC Server is also a high redundant connection possible: https://support.industry.siemens.com/cs/de/en/view/16651010 Or if you use WinCC V7/8 then you could also use the OPC UA Server and have access from outside to the PLc Tags from OPC UA Client |
