8/11/2020 7:21 AM | |
Posts: 2 Rating:
Hi I want to make s7 connection between two cpu 1500 with diffrent subnet mask: plc1 : 192.168.100.8 (255.255.255.0) plc2 : 192.168.15.4(255.255.0.0) and i want use put and get blocks. is it possible to make connection with diffrent subnet mask? if yes, how? thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/11/2020 07:44:00New subject after splitting Last edited by: pouyana at: 08/11/2020 19:01:13 |
8/11/2020 8:21 PM | |
Joined: 5/6/2010 Last visit: 8/5/2024 Posts: 1975 Rating:
Hello, with your configuration is it not possible. The reason is that PLC1 can only connect a network from 192.168.100.0 to 192.168.100.255. Please look at the manual regards |
8/17/2020 11:25 AM | |
Posts: 2 Rating:
Hello Thank you for your answer. unfortunately our firmware version is 1.8 . So the only way is changing subnet mask ? |
