4/3/2023 9:41 AM | |
Joined: 7/9/2015 Last visit: 5/29/2024 Posts: 3850 Rating: (564)
Hi, please have a look tho the following application example - it shows a solution - I think this must also work with Simatic Manager. Plant diagnostics with WinCC V7.4Regards, Towome |
4/8/2023 3:38 AM | |
Joined: 7/15/2017 Last visit: 2/14/2024 Posts: 13 Rating: (0) |
Thanks Towome for your answer. I think this way is only available if the OCM possible in the block properties is enable but in my case the the block of S7 graph has no OCM possible and you can't create WinCC attributes. So is it possible to do that for graph-block by any other way ? |
