8/8/2017 6:52 AM | |
Joined: 5/8/2017 Last visit: 4/24/2024 Posts: 23 Rating:
Hi, I have a question for writing data to PLC via S7 connection. IOT2040 is connecting with S7-1200 and panel. IP address and the setting are maybe correct. But analog data cannot display on the panel. S7-1200 and panel are connecting correctly, so maybe there is a problem between IOT2040 and S7-1200. Could you knindly tell me the solution? Thanks for your help. AttachmentStructure.zip (227 Downloads) |
8/8/2017 9:11 AM | |
Thank you for your reply. I attached text file of exported JSON code. Attachmentproject.txt (237 Downloads) |
9/7/2017 8:23 AM | |
Joined: 8/21/2014 Last visit: 7/17/2024 Posts: 1002 Rating:
New question published by Piet.pol is split to a separate thread with the subject is there a node-red module for writing data to a S7 PLC ?. Best regards |
