10/9/2009 2:13 PM | |
Joined: 10/7/2005 Last visit: 5/24/2024 Posts: 3007 Rating: (1049) |
Hello ShiRaPatil older PLCSIm version (from memory every version before V5.4 SP1 but don't quote me on that) require an MPI connection(for which you needed to set your PG/PC interface as well asCPU in your HWconfig which has an MPI port). I wonder as such if your MPI/DP port of your 317 PN/DP is set to DPin which case it would explain the problem you are having. Ideally you upgrade to the latest PLCSIM (V5.4 SP3), but as a workaround you can of course change your CPU's MPI/DP port to MPI (should the above be the problem). I hope this helps |
Cheers |
