10/17/2012 1:06 PM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating:
HelloRonald, [quote user="Ronald Halim"]and now the is the new version is offered by Siemens distributors is 6ES7414-4HM14-0AB0. Even this CPU (4HM14) has entereddiscontinuation phase. I recommend to order the 2 of the latest CPU6ES7414-5HM06-0AB0. Unfortunately you will also have to order 4 newsynchronization modules6ES7 960-1AA06-0XA0. Best regards, H-H
10/22/2012 5:52 AM | |
Posts: 7 Rating:
Hi H-H, Thanks for your advice. And how about the programm? Should we transfer the program to both CPU? Thanks again... |
10/22/2012 5:54 AM | |
Posts: 7 Rating:
Dear MANISH@TCS Thanks for your help. |
10/22/2012 6:23 PM | |
DearRonald,
You should change your hardware configuration first. To do so you will have to use STEP7 V5.5 SP2 +HF1. When you finish your modified configuration, you can download your new project to the new CPUs. Best regards, H-H
