10/25/2010 5:54 PM | |
Joined: 7/2/2008 Last visit: 7/2/2024 Posts: 928 Rating: (306)
Hello stoprak, I hope you find the following links useful. S7-400H+CP443-1 with Kepware How do you configure a fault-tolerant S7 connection for a user application via Industrial Ethernet with the SIMATIC NET PC software? How do you configure a fault-tolerant S7 connection for the SIMATIC NET OPC server via Industrial Ethernet with the SIMATIC NET PC software? Best regards. H-H |
10/26/2010 11:55 AM | |
Hello stoprak, Tothe best of my knowledge, you must go for SIMATIC Net OPC if you are going to use RED. CONNECT. I checked the KEPserver EX OPC and found that it doesn't have the required driver for redundant connection with S7-400H. Bets regards. H-H |
