3/30/2016 11:51 AM | |
Posts: 1 Rating:
Hello I have now the same error message. Do you found a solution about this Problem? |
4/25/2016 1:04 PM | |
Joined: 3/24/2009 Last visit: 6/20/2023 Posts: 535 Rating:
Dear Vampyrian, do you get warnings in the consistency check of the safety program during the compile? The communication, which is mentioned here, is the internal communication between the F-CPU and the F-IO-modules. There may be various problems, which can cause this error (already mentioned: clock-memory-bit, ...) Best reagrds, |
3/7/2019 3:32 PM | |
Joined: 5/17/2018 Last visit: 6/25/2024 Posts: 4 Rating:
Bump. We just had the exact same problem. Is there a solution? |
