5/19/2017 2:30 PM | |
Joined: 6/26/2013 Last visit: 4/23/2024 Posts: 143 Rating: (5) |
Hello Deep5310, You may need an array of strings in a DB in PLC code. Then use indirect addressing to access each string in the array one after another. Take a look at the following entries which will give you an idea on these topics: Information on the topic of "Indirect addressing" Programming a Loop with Indirect Addressing For further information, search the forum! These topics have been discussed many times. For information on how to access your string in WinCC, start a new post in WinCC Conference. If it helps, you may use rate button. |
