2/8/2017 10:47 AM | |
Joined: 11/29/2011 Last visit: 6/6/2024 Posts: 1358 Rating:
Hi, It is not always as simple as it looks. Anyways, there is a fix for that as well. Readback. See How are block parameters labeled specially for read-back?
That was the Read back.. Also there is a more conventional way to keep you parameter DB's up to date. Basically you keep the Actual values of the variables in the DB up to date. See the explanation: Let us known how are you getting on! I hope I could help! |
Last edited by: MicroMan at: 2/8/2017 11:14:40 AM- What you read here, please check with manuals and your requirements. |
2/8/2017 5:46 PM | |
Joined: 3/14/2008 Last visit: 6/14/2024 Posts: 2070 Rating:
In addition to the good explanation of Microman, I believe you can also open the online DB and press the Save button. |
