11/8/2012 8:40 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (714)
Hello, Have a look at attached example, hope you can use it for your application. Regards, Marcjan Attachmentsaw_forum.zip (188 Downloads) |
Problem solved? |
11/8/2012 11:06 AM | |
Posts: 2930 Rating: (432)
Hi, the only possiblity I belive is to use the ramp funktion. But it is not possible as you want. Please have a look to example. Here you can change the amplitide and period of the tooth at the TD. Hope this helps AttachmentD:\tmp\C__Users_SH3665_Desktop_Sägezahn saw tooth example.zip (175 Downloads) |
