5/26/2014 3:15 PM |
Posts: 60 Rating: (8) |
HELLO SIR, I AM USING AO 2xU MODULE FOR CONTROLING.FOR THAT I AM FACING SCALING PROBLEM.IT IS NOT PROPERLY GETTING. |
5/26/2014 3:31 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715)
Hello, What is the value before scaling? Let's say 0 to 100 [code]L MW 40 ITD DTR L 1.000000e+002 /R L 2.764800e+004 *R RND T PQW 264[/code] or you use fc 106 Unscaling Regards, Marcjan AttachmentFC1_forum.pdf (272 Downloads) |
This contribution was helpful to4 thankful Users |
5/29/2014 8:54 AM | |
Posts: 42 Rating: (1) |
Use FC106 and monitor the output online. Also check your wiring and make sure they are not near any power cables as they disturb the signals. |
