2/22/2017 9:25 AM | |
Joined: 7/9/2015 Last visit: 6/25/2024 Posts: 3858 Rating:
Hi, I found no information about cycle time for FC/FB calls but there are lots of infos about duration of Bit/Byte operations. Check page 22 / chapter 3.2.2 in the following manual: https://support.industry.siemens.com/cs/de/en/view/59193558 There is also a FAQ for How do you efficiently and effectively program for the S7-1200/S7-1500 in STEP 7 (TIA Portal)?I think if you use only one FC your programm code could get confusing, so I would use severeal FC´s/FB´s. Regards, Towome
2 thankful Users |
