1/30/2015 4:34 AM | |
Joined: 5/12/2006 Last visit: 10/11/2024 Posts: 22410 Rating: (3017)
Hello, a guide/manual for SIMOTION Scout TIA you found here . In Capter 6.3 you find the projecting of safety with F-Proxy which you need for you configuration. at the moment there are no restrictions but what you mean with "4 to 8 S120 in DriveCliQ"? Do you mean motormodules which are connected to the D425-2 on the DQ Ports or external S120 (CU320-2) which are connected wit PROFIBUS/PROFINET? Regards Christoph |
3/24/2016 3:01 PM | |
Joined: 3/17/2014 Last visit: 10/4/2024 Posts: 2 Rating: (0) |
Hello, Try installing the update 8 TIA Portal. You will probably have better results. |
