1/20/2023 3:51 PM | |
Joined: 7/19/2022 Last visit: 4/26/2024 Posts: 356 Rating: (60) |
Hello rokise, Since you have upgraded and it was working fine before, I recommend: - Make a backup of the project - Delete the IM folder (How do you delete the IM folder of your TIA project?). The IM folder contains temporary files that may not be overwritten correctly (through replacing graphics, for example). The folder and all the files in the folder are recreated when you compile with a complete rebuild. Therefore, deleting the IM folder offers a remedy for existing inconsistencies. - Compile everything again
Last edited by: JBS98 at: 01/20/2023 15:52:35If this Information really helps, you could use the Rate function |
