9/13/2022 8:10 AM | |
Joined: 8/3/2009 Last visit: 6/21/2024 Posts: 13104 Rating:
Hello Jazkarraga where is your question? -> What is your usecase? do you want to open a screen depending on a tag value? you cannot open a screen like in your code. there are many ways to change a screen in WinCC. If you are working without Screen windows then you could use this one: https://support.industry.siemens.com/cs/de/en/view/109792622/45951086091 But in common configurations you will always run with only one screen and work with screen windows. then the Screenchange has to look very different. Bye Murof |
