9/5/2007 5:52 AM | |
Posts: 191 Rating:
Hi!! this is an example on how could you dysplay 4 weights with just 1 load cell set your analog input to your scale 0 turn on I1 set your analog input to your scale 1st weight turn on I2 set your analog input to your scale 2nd weight turn on I3 set your analog input to your scale 3rd weight turn on I4 set your analog input to your scale 4th weight turn on I5 i hope this is what you are looking for... ROSA Attachment4 weights.zip (315 Downloads) |
9/9/2007 9:48 PM | |
Joined: 1/5/2007 Last visit: 3/16/2022 Posts: 1689 Rating:
Hello, sorry, there is no de-multiplexer available in LOGO! But, you can program an equivalent funktion. Look at the attachment. You find two Examples, one fordigital signals (a 1 to 4 de-multiplexer) and two for analoge signals (a 1 to 4 de-multiplexer). I hope you can understand the funktion and the parameters (because it is with german comments). Best regards Betel AttachmentForum_DEMO_DeMultiplexer.zip (346 Downloads) |
Last edited by: Betel at: 10.09.2007 22:08I have add a second demo for an analoge 1 to 4 de-multiplexer (with a 2-bit direct addressing of the analoge output chanels). ==> Meine TAG-Listen: "deut." |
