10/22/2010 8:29 PM | |
Posts: 3 Rating: (0) |
Hello, In this case you need to do upgrade the language like a PAC3200. In PAC3100 youneed of a converter RS232 to RS485, or use a PAC 4200 (gateway) for make the connection between the PAC3100 an your PC. Use the powerconfig to make the upgrade. http://support.automation.siemens.com/WW/view/en/31676289 Best Regard Peres |
1/5/2011 10:31 AM | |
Posts: 50 Rating: (6)
Hello, After a successfully firmware update appears the message "install text" in the device display. It means that a language pack update is necessary too. Please look to the attached file, there you can find a detailed description and examples. AttachmentExample_Description.zip (770 Downloads) |
