11/13/2020 8:46 AM | |
Joined: 2/22/2008 Last visit: 8/6/2024 Posts: 2698 Rating:
If you want have ramps, then it would be the easiest to use ready analog ramps, see example in attachment. All you need are weekly timers, analog ramps and analog amplifiers. For further informations to PH electrode we just need more details, a link or technical data for scaling. Regards, Scorp AttachmentRamps1.zip (239 Downloads) |
11/13/2020 12:23 PM | |
I am missing technical data at your linked pH sensor, e.g. supply voltage and analog signal depending on pH value. Therefore you have to search for more data or ask the vendor. See attachment for the rest of your questions and a possible scaling of a pH sensor with 0..10V output for pH value auf 0..14. Regards, Scorp AttachmentRamps2.zip (235 Downloads) |
