11/10/2008 5:35 AM | |
Joined: 9/27/2006 Last visit: 8/8/2024 Posts: 12273 Rating:
Hello; The following Siemens manual (S7-300 Module Data) presents all available digital and analog module specifications. http://support.automation.siemens.com/WW/view/en/8859629 One of the data provided for eachmodule is the cable length it supports for different cable types. See theattachment I prepared. Hope this helps, Daniel Chartier Edit: I just noticed you did not mention if the system you are using is for S7-400 CPUs; module info can be found here: http://support.automation.siemens.com/WW/view/en/1117740 For S7-200 CPus, you will find this information in the appendices of the S7-200 System Manual: http://support.automation.siemens.com/WW/view/en/1109582 D.C. |
11/12/2008 3:16 AM | |
Posts: 47 Rating:
Hello Record order number or name of ther module and access internet and .... rearch |
