6/14/2011 7:16 AM | |
Joined: 10/7/2005 Last visit: 4/28/2024 Posts: 3004 Rating: (1046) |
Hello Mathias_Popsel perhaps this Block will help you (more so if you work with puresymbol based DB's inTIA Portal): How can you group separate signals (variables of the "Bool" data type) to one variable of the "Word" type and again extract them from that "Word" variable (Bool - Word data type conversion)? |
Cheers |
6/14/2011 11:23 AM | |
Posts: 19 Rating: (0) |
Hi fritz, I can not use this block ( i am using V5.4SP4) are there similar blocks i can use? Thanks a lot! |
6/14/2011 11:38 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181) |
This is because put your issue in wrong conference. Anyway look there - /tf/WW/en/Posts/56184 |
