6/11/2014 8:42 PM | |
Joined: 9/27/2006 Last visit: 6/29/2024 Posts: 12264 Rating:
Hello Ingenious; Start by looking at the following FAQ, you should have enough information to work with: How can you read out the date and time with SFC1 (READ_CLK) and input them with SFC0 (SET_CLK)? You can create a DT variable in a DB if you wish, instead of a Temp variable as used in the example code. Hope this helps, Daniel Chartier |
6/12/2014 10:00 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Extract Hour, Minutes and Secs, in Integer form from TOD format - SCL Code take a look atsmiffy's code.
6/12/2014 12:05 PM | |
Joined: 8/22/2013 Last visit: 4/21/2024 Posts: 36 Rating:
Hi everynone, Thanku very much, now its clear. |
2 thankful Users |
