11/6/2023 7:48 PM | |
Joined: 11/3/2023 Last visit: 11/11/2023 Posts: 3 Rating:
Dear all, Really grateful for you contribution in this issue, and sorry for late response as the vessel was engaged with critical operation , - Pls. find attached some more clear photos . - Unfortunately we do not have the right PC Adaptor USB so we could not get into the CPU for deep checks, we expect to have it in the next two days, then, I will revert to you with the results. - For this kind of fault, what is the possibility to loose the program/software of the CPU? - What is the exact function of the MMC? , is it just a backup for the software inside the CPU ? as you can see in the picture and video, the SF error is gone once the MMC is out , and came back once the MMC is in, error pls. note, when the MMC is out, the SF error disappeared, but the system still not working. - We have tried to insert the MMC into standard memory reader to a laptop, but it could not be read,later we new that we must have a certain software or hardware from Siemens to to that, is their any work around this? pls. advise. Thanks again for you all. AttachmentCPU.zip (393 Downloads) |
