12/25/2010 12:25 AM | |
Posts: 4 Rating: (0) |
sir iam new for siemens controller so pls clear my problems ,and tell me where i get technical artical on siemens controller. thank u |
12/25/2010 11:23 AM | |
Posts: 2964 Rating: (484) |
Hi... 1)Referencing remains same for 810D-840D but depens upon what type of motor are you using it Inceremental encoder - referecence required when ever machine is switched OFF and ON Absolute encoder- Reference not required. One time referencing....motor is installed if motor / ballscrew is distrubed you need to do it again attaching you the PDF of the same for the reference. 2) You need to install the Simatic manager Step7 on HMI then you can able to see PLC. 3) What exactly you need the basic details( NC /PLC)? i am attaching you the link check out....which may be useful /tf/WW/en/Posts/45391#top Regards, Ekalavya Attachmentinceremetal_absolute.pdf (310 Downloads) |
12/25/2010 10:48 PM | |
thank you ekalvya very useful data for me. i wantinformationaboutNC |
12/26/2010 8:18 AM | |
Hi.... You can refere 810D/840D/611D Startup Guide https://www.automation.siemens.com/doconweb/content.asp?item=2735&cd=sinumerik_simodrive_04_2010_e&scope=all Regards, Ekalavya |
1/5/2011 8:40 AM | |
Posts: 63 Rating: (2) |
Dear |
1/7/2011 1:05 AM | |
thank you ekalavya and gadhaveji, its very useful to me. |
Last edited by: kamlesh shah at: 1/7/2011 1:07 AMLast edited by: kamlesh shah at: 1/7/2011 1:06 AM |
