7/14/2014 4:29 PM | |
Posts: 220 Rating: (11) |
I don't know what you want to do with this hardware, but normally you use S7-400 CPU for PCS 7. With a S7-300 CPU you can just use the Industrie Library in PCS 7, cause the S7-300 CPU don't support all functions you need for all PCS 7 librarys. Futhermore do you checked, if your selection released for PCS 7? To check these search for the Manuall "SIMATIC Process Control System PCS 7 Released Modules" of your PCS 7 Version. In the Manual find you all released Modules for your PCS 7 Version.
3/4/2015 3:17 PM | |
Joined: 4/14/2010 Last visit: 8/6/2024 Posts: 525 Rating: (11) |
Thanks for message, not using PCS 7 we will use WinCC flexible advanced 2008. We have one job regarding Process Automation and want to remote monitoring of 25 instruments of Endress + Hauser with Profibus_PA communication protocol and 05 with 4..20mA output. Could you please confirm the following order code
configuration is sufficient or anything else required in this regard,
This configuration with bus modules and power supply (see attached) CPU 314C-2PN/DP 6ES7314-6EH04-0AB0 = 01 nos. WINCC FLEXIBLE /ARCHIVES 6AV6618-7ED01-3AB0 = 01 nos. Regard's AttachmentSiemens Industry Online Support - Automation Service, Automation Support, Simatic Service,.pdf (56 Downloads) |
MS |
3/4/2015 4:07 PM | |
Posts: 46 Rating: (3) |
Hi as you use WinCC Flexible I would do the engineering according to these two manuals: SIMATIC HMI WinCC flexible 2008 Communication Part 1 SIMATIC HMI WinCC flexible 2008 Communication Part 2 In Part 1, chapter 2.1.1 you find a list of possible communication partners for WinCC flexible. I hope it helps you engineering your system. |
3/5/2015 8:06 AM | |
Thanks for message, we have experience about communication between HMI WinCC flexible 2008 and SIMATIC controllers S7-300. Now we need your verification about Profibus_PA connection technology please confirm the following items, is it sufficient or anything else. CPU 314C-2PN/DP 6ES7314-6EH04-0AB0 = 01 nos. Regard's |
MS |
