5/13/2020 3:26 PM | |
Joined: 9/27/2006 Last visit: 5/5/2024 Posts: 12257 Rating: (2666) |
Hello dzejkob; I believe the Omron CJ series supports Hostlink, and so do the Siemens Comfort panels. See the link below, taken from the following manual: SIMATIC HMI HMI devices Comfort Panels https://support.industry.siemens.com/cs/ww/en/view/49313233 What version of WinCC are you using to program the Comfort HMI? You can search the online help for details on commissioning the connection. If you do not have access to Hostlink for any reason, can you use Modbus (RTU, TCP), or any of the other communication protocols mentioned? For example, here you will find a CSP for Comfort panles using Ethernet/IP eith Omron controllers: https://support.industry.siemens.com/cs/ww/en/view/109739698 Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 05/13/2020 15:28:23Last edited by: dchartier at: 05/13/2020 17:37:26 |
