2/5/2024 5:47 PM | |
Joined: 3/14/2008 Last visit: 7/11/2024 Posts: 2075 Rating:
Can you provide more info, with screenshots to show the problem. |
2/8/2024 4:06 PM | |
Hi, The solution can be simplified in my opinion. It it used for counting days? Take a look at the CountOh block then, which can do it probably a better way. I think there is some kind of freeze function with one of the selector (SEL_R) blocks. |
