11/20/2023 3:42 PM | |
Joined: 5/6/2022 Last visit: 7/30/2024 Posts: 436 Rating:
I tell you, the Unified panels file with SQLite format, this is the procedure, I will share it with you below: You can also follow what is explained very well in the following link to a YouTube video: "WinCC Unified V16: export logged tags as a daily .CSV report (last 24 hours)" and choose the trigger you want to export to csv. From the controls, such as a curve viewer, you can also export the values to csv: And this example is quite useful: I hope all this information can help you! Best regards!
