4/13/2014 10:10 PM | |
Posts: 2 Rating: (0) |
I'm working on a Printing press year 2000 vintage. It uses a simadyn d to sinc 4 dc drives for a shaft less drive line. List of components sp22.5, PM6,IT41,EA12,CS7-ss5-ss4-ss4,CS7-na-ss52-ss52,na,PM16 Last week the power supply failed at speed with a red fault. Lost +15 Replaced with used ps. Now afterboot up it flashes"C". Diagnostics Show "Coupling memory (L-bus) not ok" "Coupling Memory (C-bus) not ok" Changed out PM6 Same thing. In the process I have check every card, jumpers I attached a copy of the diagnostics could someone take a look,"not shure if it worked I had to zip it because it was a TXT file"there is a lot that I have no idea what I looking at. Any help would be great this machines been down for a week thing are getting a bit spooky around here.
AttachmentDebug all Diagnostics eng.zip (163 Downloads) |
10/10/2014 9:16 AM |
Posts: 1 Rating: (0) |
it may help u please check /tf/WW/en/Posts/102143#top
