9/28/2023 2:12 PM | |
Joined: 9/12/2023 Last visit: 10/10/2023 Posts: 1 Rating:
Hello Responsible user: SYSTEM Compiling all charts as program SIMATIC H Station(1)\CPU 414-4 H\S7 Program(1) on 9/23/2023 2:39:10 AM Generate block drivers: on Generating SCL sources: off Set sampling times from 9/23/2023 2:48:19 AM Setting sampling times completed: 9/23/2023 2:48:20 AM. W: The program or chart contains F blocks, however, the SIMATIC F System is not installed or installed incompletely. End of code generator: 9/23/2023 2:50:48 AM E: CAUTION: OB88: call for FC750 is missing ! E: CAUTION: OB1: call for FC0 is missing ! E: CAUTION: OB80: call for FC742 is missing ! Many thanks for your guidance ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/29/2023 08:09:19New subject after splitting |
9/28/2023 2:42 PM | |
Joined: 7/5/2013 Last visit: 7/18/2024 Posts: 3107 Rating:
Hi,
I guess S7 F Systems optional package must be installed. See documentation in knowledge base entry SIMATIC Industrial software SIMATIC S7 F/FH Systems - Configuring and Programming. Regards, Frink |
Pi is exactly three! |
