1/13/2012 1:17 PM | |
Posts: 267 Rating:
Hello, for AS-i communication with the S7-1200 you need the AS-i Master CM 1243-2 (3RK7243-2AA30-0XB0): http://support.automation.siemens.com/WW/view/en/43416171 and you needa AS-i power supply: e.g. DCM 1271 (3RK7271-1AA30-0AA0): http://support.automation.siemens.com/WW/view/en/43416176 sorry, for a firmware update you need the S7 MEMORY CARD, 24 MB(6ES7954-8LF00-0AA0): http://support.automation.siemens.com/WW/view/en/34983889 there is no way to format a SD card for it! |
1/16/2012 12:29 PM | |
Posts: 5 Rating:
Do i really need the As-i power module when i already got the pepperl+fuchs as-i powerhttp://www.pepperl-fuchs.com/global/en/classid_200.htm?view=productdetails&prodid=17961? |
1/16/2012 12:37 PM | |
Posts: 267 Rating:
I think this also works. |
1/16/2012 12:52 PM | |
Posts: 5 Rating:
I have this gateway from pepperl+fuchs: http://www.pepperl-fuchs.co.uk/great_britain/en/classid_199.htm?view=productdetails&prodid=32236 And this as-i power supply from pepperl+fuchs :http://www.pepperl-fuchs.com/global/en/classid_200.htm?view=productdetails&prodid=17961 Can theDCM 1271 module replace both of these components? |
Last edited by: Sebastian.g at: 1/18/2012 8:25 PMLast edited by: Sebastian.g at: 1/16/2012 1:48 PM |
1/16/2012 1:19 PM | |
Posts: 267 Rating:
Sorry, I don't know these modules and their functions. Perhaps the manual will help you: http://support.automation.siemens.com/WW/view/de/57358958/0/en |
