12/28/2020 4:30 PM | |
Joined: 9/3/2008 Last visit: 5/8/2024 Posts: 921 Rating: (158) |
Hello, You need Windows 10, build 1709 to 2004 for WinCC Professional v15.1 to be compatible with Windows 10. Check the compatibility using: https://support.industry.siemens.com/kompatool to see the specifics for each build. Regards |
Michael |
12/28/2020 10:42 PM | |
Joined: 10/23/2020 Last visit: 7/22/2022 Posts: 5 Rating: (0) |
Do you think that the (my) problem is the Windows version? Thanks |
3/6/2024 6:15 AM | |
Joined: 7/10/2018 Last visit: 5/10/2024 Posts: 5 Rating: (0) |
Hello. I have a similar problem. Have you solved your problem? |
