10/4/2022 7:04 AM | |
Joined: 6/16/2022 Last visit: 10/5/2022 Posts: 2 Rating: (1) |
Wish to know the solution too |
10/4/2022 12:55 PM | |
Joined: 8/3/2009 Last visit: 8/2/2024 Posts: 13446 Rating: (1703)
Hello I would say, check this FAQ: https://support.industry.siemens.com/cs/ww/en/view/109795515 It is not alowed to change the audit File this is against the GMP rules. At Comfort Panels there are regional settings with specific delimiter. The same you have to set in your Windows regional Settings to open the Audit file in the viewer properly Bye Murof |
Last edited by: Murof at: 10/04/2022 12:58:07If this Information really helps, you could use the Rate function |
