6/20/2024 10:30 AM | |
Joined: 10/30/2022 Last visit: 10/3/2024 Posts: 5 Rating: (0) |
Hello , I'm reopening this post because I'm in the same situation. I looked at the answer given but I still don't understand how to read the DB of my S7 1500. I tried to use the ReadDataBlock but without success. I have tried to use the ReadDataBlock but to no avail. Could one of you explain how to do this as even the documentation is pretty poor or I haven't found the right one. thank you Mike ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/21/2024 08:40:19New subject after splitting. Quote inserted. |
6/25/2024 9:49 AM | |
Hello guys , anyone can help on that topic ? best regards Mike |
6/28/2024 6:40 PM | |
Joined: 7/7/2010 Last visit: 10/11/2024 Posts: 15292 Rating: (2427)
From the original topic your topic was split from contains all the answers. Did you use PLCSIM Advanced along with a user-defined coupling in SIMIT to enable DB access on the s7-1500 simulated PLC? Did you contact your regional technical support team and they refused to help? When you visited ( https://support.industry.siemens.com/cs/document/109795246/simit-couplings-applicative-expansions-of-the-interface?dti=0&lc=en-WW ) "SIMIT Couplings, applicative expansions of the interface), did you not find the sample TIA Portal application and coupling code at ( https://support.industry.siemens.com/cs/document/109794472 ) If not, you have wasted a lot of other peoples - and especially my - time.
science guy |
