8/28/2019 9:33 AM | |
Joined: 5/3/2017 Last visit: 5/21/2024 Posts: 673 Rating:
Hello mike099@f2s.com, Can you please check that the PLCSIM in the mode RUN after you load the program? And in the application example Simulation with SIMIT and SIMATIC PCS 7 using a practical example you can find an example how to configure the communication between PLCSIM and SIMIT. with regards |
4/17/2024 11:08 AM | |
Joined: 9/27/2016 Last visit: 7/19/2024 Posts: 5 Rating:
Hi Mike, I'm facing the same problem (with a newer versions). Did you reach some solution? Regards, Iván |
