12/16/2013 6:17 AM | |
Posts: 262 Rating: (45) |
Hi, Just check Test position feedback is ON or not... If not, just "tick" in the box. Your problem will be resolved for normal Direct online application. |
5/14/2014 6:52 AM | |
Posts: 235 Rating: (52) |
Dear nicopoi, I dont know wahat was you are phasing in it but finnd the aatached wiring drawing for same. And also note that as per my knowledge pro-v require run feedback to working continue and for this feedback you must to give contionue suplly to stop command for the same. Attachmentpro-v wr.pdf (611 Downloads) |
5/20/2014 9:31 AM | |
Posts: 340 Rating: (6) |
new question is splittet to problem with getting signal flow and status on win7 pc?. |
