6/16/2019 5:55 AM | |
Hello, You should have post this query in SIMODRIVE Converter system product conference. BTW, have you faced this problem after replacement of E/R module? Was the old E/R module working perfectly i.e. READY signal working OK? If you have replaced E/R module, have you set DP switch position correctly as per supply voltage? Check the S1.2 switch position & compare with the older/original E/R module. Please refer the attached sheets for detail information. P. S. - DIP switch location is at TOP left side of E/R module. |
