8/23/2023 9:44 PM | |
Joined: 10/17/2007 Last visit: 6/6/2024 Posts: 4002 Rating: (347)
Your Picture showing Power supply, But I can see a liitle parts of Drive control card, please shut off power taking out flat cable, picture the drive control card at the right of this picture --it should be 6SN1121-xxxx-yyyy, I need that numbers. I supose you have 611A spindle control card, see attached picture, ther are output relay terminal , you can get signal from A31 you need set Parameter P021=0, means speed >0 output signal to A31 don't do now, after my confirm your next picture
Attachment611A_SP_outputA31.pdf (282 Downloads) |
If you like my comments please |
