8/11/2010 6:47 AM | |
Posts: 2964 Rating: (482) |
Hello.... Could you send the photograph of this card and the motor and your PC based control how connection is given... if the card is with analog the motor will be with 1FT5 series... i am attaching you the analog motor configuration steps.... check it out it may helpful to you.... Regards, Ekalavya Attachment611A_startup.pdf (290 Downloads) |
