2/10/2011 10:53 AM | |
Posts: 2964 Rating: (479)
Hi.... IF EMERGENCY STOP PB IS PRESSED, ONLY 64 SHOULD GET DISABLED TO PROVIDE INSTANT BRAKING. 63 AND 48 WILL ALWAYS BE ENABLED. IF POWER FAILURE OCCURS, THE SITOP SWITCHES OFF , HENCE REMOVING ONLY 64. 63 AND 48 WILL STILL BE ENABLED FOR A FEW SECONDS DUE TO THE RESIDUAL POWER SUPPLIED FROM THE DC LINK. THIS WILL AID IN CORRECT REGENERATION AND DISABLING SEQUENCE Checkthis PDF for more details..... for Wiring I/R module. Regards, Ekalavya AttachmentSTANDARD WIRING DIAGRAM OF THE I.pdf (202 Downloads) |
