5/15/2023 10:26 PM | |
Joined: 12/3/2022 Last visit: 5/17/2023 Posts: 9 Rating:
Hello Can any one help ? Thank you Regards |
5/16/2023 9:36 PM | |
Joined: 10/17/2007 Last visit: 7/14/2024 Posts: 4008 Rating:
Read attached book, HS/5-58, you will have detail for all Fault If you want to test the control card you MUST have spindle motor (with encoder of course) F-09 can be supressed --see attach, book F09 F-19 can be suppresed by jumper 14--15 by 300 ohm resistor --it is you risk as this iS my tips for you Not Siemens standard 14, 15 means spindle motor encoder connector 15 pin- D-type to control card--check ch.6 atcched book PS: in the future attache Siemens parts number in full and in correct format no one know what is 6SN1121--SHOULD BE 6SN1121-1BA12-0AA1 NO ONE KNOW 6SN1145 --????? as your post a picture or I will not answer you
AttachmentIAA_1000_en.pdf (337 Downloads) |
Last edited by: nulizhang at: 05/16/2023 21:37:03Last edited by: nulizhang at: 05/16/2023 21:51:04If you like my comments please |
