10/13/2021 10:49 AM | |
Posts: 1 Rating:
WE ARE HAVING SIMODRIVE ALONG WITH 840D CNC SYSTEM. IS IT RECOMMENDED TO RUN THE MACHINE WITHOUT LINE FILTER? RECENTLY THE INSTALLED LINE FILTER GOT OVER HEATED AND I DO NOT HAVE SPARE ONE. WHAT ARE THE PROBABLE CAUSES FOR THIS AND WHAT THINGS I HAVE TO CHECK TO ELIMINATE THE PROBLEM. ------------------------------------------------------------------------------------------ |
Last edited by: JAGA 21 at: 10/13/2021 10:59:22Last edited by: Jen_Moderator at: 10/13/2021 11:49:20New subject after splitting |
10/13/2021 6:16 PM | |
Joined: 10/17/2007 Last visit: 6/26/2024 Posts: 4007 Rating:
"NO" is my answer. It is possible to damage more HW, maybe Power supply module. the best is you find replacement asap. what the size of your Power supply module? you need to check it or replaced that as well to test .
