11/29/2014 1:48 PM | |
Posts: 5 Rating:
im using step 7 v5.5, i used a simple circuit in FB for ODT 3s timer. i called it twice in my OB1 but it only works if there is 1 of them. having 2 FBs make the funcionality improper pls helpHELP pls :( |
11/29/2014 9:31 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello, You can't use theS5 Timers in a FB, ifthe FBis called multiple times. Have a look at attached pdf to use IEC Timers in multiple instance calls. Regards, Marcjan AttachmentTimer in FB.pdf (448 Downloads) |
Problem solved? |
12/1/2014 6:40 AM | |
Posts: 5 Rating:
THANKS A LOT :D |
12/1/2014 7:30 AM | |
Well, there is another way to use timers in a FB, you have to bring the timer numbers outside the FB, see attachment. you could also create your own timers. regards, Marcjan AttachmentFB1.pdf (340 Downloads) |
Problem solved? |
