9/13/2012 10:22 AM | |
Posts: 18 Rating: (0) |
Hi everbody I wanted to know is there any simulator for s5 and step 5 for window is there simulator? best regards |
9/13/2012 11:34 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (713) |
Hello, I believe Siemens has/had not, but maybe you can get it here. Why you need it, if it is for learning better use Step 7. Regards, Marcjan |
Problem solved? |
9/15/2012 7:22 AM | |
hello thank you so much I need to have the simulator because the customer wants best regards |
9/15/2012 10:17 AM | |
Joined: 12/1/2009 Last visit: 3/31/2024 Posts: 672 Rating: (147) |
Dear sarana6, there isa productfor process simulation called SIMBA. As I remember it does not replace the central controller, just it's attached I/O's with the process. I could not find the previousS5version ontheir website. https://www.industry.siemens.com/services/global/en/cross_industry_solutions/automation_it/simul_test/Pages/Default.aspx?HTTPS=REDIR You might can send them an email. Best Regards. |
Give us your feedback and show us your respect! |
