1/9/2023 5:39 AM | |
Joined: 3/1/2018 Last visit: 9/2/2024 Posts: 37 Rating: (13) |
Hello! There is no way (at least until today) to use the SINAMICS as OPC DA server directly! If you want to use OPC DA you need something to read the data from drive and provide to clients, like this example here that uses the SIMATIC NET Softnet IE S7 to provide the data.
Attachment81555951_Accessing_SINAMICS_parameters_via_SIMATIC_NET_OPC_V1_1_en.pdf (378 Downloads) |
Last edited by: Jen_Moderator at: 01/09/2023 08:51:27PDF attached from link. Best Regards, |
