8/26/2020 12:32 PM | |
Joined: 10/11/2006 Last visit: 5/23/2024 Posts: 5852 Rating: (793)
Hello, in case you want to use an analog input of your TM31 as a speed setpoint, you can interconnect the analog input (r4055) of TM31 via BICO interconnection to your speed setpoint (p1155) of your axis. You don't need a telegram for this use case. In case you want to learn more about telegrams, you can have a look into the S120 list manual, chapter 3.9 https://support.industry.siemens.com/cs/ww/en/view/109763271. There is an overview of all telegrams and which parameters will be sent to the PLC. |
With best regards, |
