4/20/2023 9:46 AM | |
Joined: 10/11/2006 Last visit: 9/9/2024 Posts: 5902 Rating: (803)
Hello, Depending on your stopping command the brake is closed immediately or delay after deceleration ramp. During start magnetisation time and brake opening time are the influencing parameters. |
With best regards, |
4/20/2023 11:20 AM | |
Joined: 6/25/2022 Last visit: 12/18/2023 Posts: 2 Rating: (0) |
Even changing the parameters P1216 and P1217, the opening of the holding brake takes time, causing a failure in the inverter A501, but if when I bypass the brake it works normally
